Our supplier had a heat treated car
Our supplier had a heat treated carbon steel heat exchanger that was in a storage yard and something caused a dent in the shell there. The supplier is not able to tell us how or what happened, but it looks like maybe a trailer was backed into it. Anyway, there is now a dent in the shell about 9” from the head seam and is located past the last baffle so the bundle should pull easily. The dent is approximately 5/16” deep and the affected area is about 18” in diameter. The heat exchanger has been transported back to supplier shop for repair. We asked for a CA plan from the supplier to correct the dent. The supplier gave us the below,
Jack out the dent with a 250 ton hydraulic jack by placing a curved plate that matches the inside shell radius between the jack and the shell.
Some heat may be applied, but will be controlled to under 500 deg. F.
Dress the area on the outside of the shell by grinding smooth.
Ultrasonic thickness check the shell and record the readings.
Reassemble the exchanger with new gaskets and hydrotest.
Blast and repaint and ship prep.
Is the above acceptable?
My concern is given the fact that the exchanger was heat treated already shouldn't it be heat treated once again after restoring the contour. Is there a ASME Code requirement that governs when a re- heat treatment is required? Please give me your feedback with respect to ASME inspection and heat treating requirements.
RE: Our supplier had a heat treated car
r6155
For instance, if this was in amine or caustic service, not a chance I'd allow it without heat treatment.
Nathan Brink
Ehzin
1) 100% UT on affected area
2) 100% PT or MT inside and outside on affected area
If 1) and 2) are OK, continue with hydrotest.
r6155
