collect Solid Body from deformable feature in nx journal
Hi guys -
I'm struggling a bit, when I try to collect solid bodies from current workaprt into a array (of Body) in nx journal..
I can easily collect the solid bodies created from ordinary features, but the bodies from the special featureType "FLEXED_PART",is challenge me a bit....
CODE -->
Dim bodies() As body = workpart.bodies.toarray
        For Each tmpbody As body In bodies
            nx(tmpbody.tag)
        Next
Do any of you have tried to play with these solid bodies created from a "deformable part"- what I mean is - to collect these bodies as solid bodies...
lklo
RE: collect Solid Body from deformable feature in nx journal
You can get all the bodies in the currently displayed assembly by using the .CycleObjsInPart method.
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
        Const undoMarkName As String = "report assembly bodies"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim theBodies As New List(Of Body)
        theBodies = AskAllBodies(theSession.Parts.Display)
        For Each tempBody As Body In theBodies
            lw.WriteLine("isOccurrence: " & tempBody.IsOccurrence.ToString)
            If tempBody.IsOccurrence Then
                lw.WriteLine("OwningComponent: " & tempBody.OwningComponent.DisplayName)
                lw.WriteLine("Parent: " & tempBody.OwningComponent.Parent.DisplayName)
                lw.WriteLine("isPartDeformable: " & theUfSession.Assem.IsPartDeformable(tempBody.OwningComponent.Prototype.OwningPart.Tag).ToString)
                If theUfSession.Assem.IsPartDeformable(tempBody.OwningComponent.Prototype.OwningPart.Tag) Then
                    Dim theDeformedFeatureTag As Tag = Tag.Null
                    theUfSession.Assem.AskDisplayedDeformationOfPartOcc(tempBody.OwningComponent.Tag, theDeformedFeatureTag)
                    lw.WriteLine("isDeformed in the display part: " & (Not theDeformedFeatureTag = Tag.Null).ToString)
                End If
            Else
                lw.WriteLine("OwningPart: " & tempBody.OwningPart.Leaf)
            End If
            lw.WriteLine("")
        Next
        lw.Close()
    End Sub
    Function AskAllBodies(ByVal thePart As Part) As List(Of Body)
        Dim aBodyTag As Tag = Tag.Null
        Do
            theUfSession.Obj.CycleObjsInPart(thePart.Tag, _
                UFConstants.UF_solid_type, aBodyTag)
            If aBodyTag = Tag.Null Then
                Exit Do
            End If
            Dim theType As Integer, theSubtype As Integer
            theUfSession.Obj.AskTypeAndSubtype(aBodyTag, theType, theSubtype)
            If theSubtype = UFConstants.UF_solid_body_subtype Then
                theBodies.Add(Utilities.NXObjectManager.Get(aBodyTag))
            End If
        Loop While True
        Return theBodies
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
