Application of ASTM A20 requirements for testing of ASTM A516 plates
Dear All,
During my review of an material test certificate of A516 Gr70 plate material,the supplier has qualified the UT testing of a plate to level B. I raised a query of why not qualified for level C, which is the stringent one and as required by ASTM A20 requirement also. However received an response from supplier that the applicability of ASTM A20 shall apply only to non heat treated plates and or plates only with stress relieving, as indicated on section 1.4 of A516.
Is ASTM A20 not applicable for heat treated or normalized material. Please confirm.
RE: Application of ASTM A20 requirements for testing of ASTM A516 plates
SA-516, 1.4 refers to plate produced from coil and furnished w/o heat treat or with stress relief only. I don't see that SA-516 or SA-20 either one requires UT for any plate condition. If UT per SA-578 is performed, the purchase shall specify the acceptance level.
Looks like the supplier UT'd even though not required, and picked the acceptance level.
Mike
If ASTM A20 is not applicable for heat treated plates ( normalized) as indicated in section 1.4, then my question is how to determine the level of acceptance criteria (A, B or C) as per A578??
UT and acceptance criteria is only as specified by the buyer.
You need to carefully read both specifications.
Mike
But I guess ET1983 requires a little more clarification.
UT is specified for non-heat treated and/or stress relieved steels as there could be cold cracks during or after cold rolling.
However, normalization is done during hot rolling, thereby enhancing the toughness of the steel. Cold cracking is not envisaged and hence the code does not ask for UT.
