Plate Bearing Test
Plate Bearing Test
Plate bearing test applies load to the ground via a 300mm x 300mm steel plate. From the test, the load vs settlement and time vs settlement plots are given.
From the plate bearing test, how to get:
1. Ultimate bearing capacity for an actual footing with a size much bigger than the steel plate ?
2. What is the settlement of the actual footing under service load?
3. Any difference between clay and sand ?
RE: Plate Bearing Test
To your question, you can't extrapolate your load test data too far beyond your test parameters. Don't try to use results from 1ft x 1ft on anything bigger than a 3 ft x 3 ft spread footing. For a 1ft x 1ft plate, your results are valid for 2 - 3 feet depth. Not too meaningful for most multi-story structure foundations.
Settlement estimates should be based on sufficient subsurface exploration, lab tests, and geotechnical calculations.
In general, plate load test results are abused more often than not.
Parry, R.G. (1948) Geotechnique28, No 1. 107-118
