What is Europian standard for piping equivalent to ASME B36.10M
Hi, I am looking for European standard for seamless and welded piping dimensions for normal and high pressure application something similar to ASME B36.10M. Any one can help? It should be DIN EIN xxx something.
RE: What is Europian standard for piping equivalent to ASME B36.10M
Now that there is only one line pipe code ISO 3183 / API 5L there is only one size code AFAIK.
However different pipe or tubing should then reference something about dimensions if it's any different.
The M bit stands for metric so should be OK.
Otherwise try EN 10220 https://www.pipingonline.com/pipes/european_pipe_s...
https://www.en-standard.eu/csn-en-10220-seamless-a...
ISO 1127 is the current standard, which has superseded the former DIN 2462 (which I think is the one the OP referenced).
/edt @ LI; EN 10220 is a product standard, whereas ISO 1127 seems to be more on it's own (i.e. general) I believe.
Somewhere within 13480 it should tell you which standard it uses.
EN 10253 is the fittings standard which is arranged more like B36.10 which is simply a dimensional standard.
Exactly. Refer to EN ISO 1127 (see my 1st reply). For the material standard of pipe n tube, you can also refer to e.g. EN 10216-5 (smls aust SS) or 10217-7 (wldd aust SS), but theyre not similar to B36.1x, since they specify chemical, mechanical etc requirements. EN ISO 1127 is the most approximate EN equivalent for B36.1x.
Thats something you need to engineer/design, as per your design code. Whats the code of construction?
