Need simple c++ Source code for Plate analysis
working on the analysis of simply supported plates carrying a point load not nessesarry at midspan (using the DKT and MINDLIN plate bending elements) .Having problems with the programming bit of it.i'm looking for a simply c++ program/source code(don't want commercial program) that solves the above problem by coding the above plate elements and go on to give the deformation and then stresss at desired points in the plate.pls anyone with useful link/information? could use a Fortran source code in the abscence of a c++ code. thanks.
