welding procedure qualification
Good Morning Friends
welding procedure is qualified up to 1".
can i qualified my welder to do welding on 1.250 " so he will qualified up to 3" by using same welding procedure.
my answer is no , but still want to verified.
stan
stan
RE: welding procedure qualification
Standard Designation: BPV Section IX
Edition/Addenda: 2015
Para./Fig./Table No: QW-301.2 and QW-350
Subject Description: SC IX; QW-301.2, QW-350, QW-404.30 and Table QW-452.1(b) – Weld Deposit Limit for WPS and Performance Qualification
Date Issued: 08/24/2017
Record Number: 17-747
Interpretation Number : BPV IX-17-50
Question(s) and Reply(ies):
Question: May a WPS that is qualified for a maximum weld deposit thickness of 0.464 inch be used to qualify a welder for the maximum to be welded using a 0.625 inch weld test coupon?
Reply: No.
A welder may not weld beyond the WPS qualified thickness unless he is welding a PQR test coupon for qualifying a WPS.
As per welding procedure , welder is qualified up to 1" or production.
If welder do test coupon 1" by using above procedure then he should qualified to 2".
Please advice.
See Table QW-452.1(b)
As others have stated, 3 layers minimum required.
If a welder qualifies on a 1" coupon with at least 3 layers deposited, he is also qualified to weld unlimited thicknesses; however, he may not weld beyond the thickness established in the WPS.
