ductwork for a laser dust collector
We are almost done installing an Amada 2415 laser and wanted to know if 40 feet of 10 inch ducting from the laser to a Torit 10 hp dust collector would work. We had to mount the dust collector outside the building due to space restraints and there would be 3 90 degree wide sweep elbows involved. I have gotten mixed answers from Amada and from Torit on this situation and even 2 differing answers from 2 local HVAC companies here in town. Does anyone know the cfm at the laser that would have to be pulled from the laser to the dust collector? Thanks for any answers.
RE: ductwork for a laser dust collector
B.E.
You are judged not by what you know, but by what you can do.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
The challenges Chris K mentions regarding dust collectors outside the building are real. For dust collector to work correctly you'll need to provide make up air or keep an outside door open at all times.
B.E.
