Rustication strips on exposed concrete with discontinuous horizontal wall reinforcement
Hi everyone,
I was checking out the book "Architectural Detailing: Function - Constructibility - Aesthetics" by Edward Allen and Patrick Rand, and the following detail related to rustication strips on exposed concrete with discontinuous horizontal wall reinforcement (attached, no copyright infringement intended) appeared:
"As recommended by ACI, we discontinue half the horizontal reinforcing bars at each control joint to help create a plane of weakness"
Does anyone know why on earth would one need to create a weakness plane there? I still haven't figured it out. Is it shrinkage related? Because I was told rustication strips are aesthetically related details only.
Thanks and best regards.
RE: Rustication strips on exposed concrete with discontinuous horizontal wall reinforcement
The lower detail is a plan view near the corner; curtailing half of the horizontal reinforcement and introducing the rustication strips creates a vertical control joint or plane of weakness and is used to prevent unsightly cracking from temperature and shrinkage.
BA
