Grade 8 bolts
Grade 8 bolts
Grade 8 bolts
Hi, I am new to the site and I hope someone can help me!  I am looking for some specifications on grade 8 bolts, the whole size range.  I have searched relentlessly on the internet and have come up empty handed.  If someone could give me the spec sheets or a link to a site that has them I would be eternally greatful!! Thanks
RE: Grade 8 bolts
When all else fails, check your McMaster-Carr catalog, they are online, too, & have all sizes, etc.
Grade 8 spec. is SAE J429 (www.sae.org); see also ASTM A354 (www.astm.org) for something roughly equivalent.
SAE Standard
Document Number: J429
Date Published: January 1999
Title: Mechanical and Material Requirements for Externally Threaded Fasteners
Scope:
This SAE Standard covers the mechanical and material requirements for inch-series steel bolts, screws, studs, sems, and U-bolts used in automotive and related industries in sizes to 1-1/2 in inclusive. The term "stud" as referred to herein applies to a cylindrical rod of moderate length threaded on either one or both ends or throughout its entire length. It does not apply to headed, collared, or similar products which are more closely characterized by requirements shown herein for bolts. The mechanical properties included in Table 1 were compiled at an ambient temperature of approximately 20 °C (68 °F). These properties are valid within a temperature range which depends upon the material grade used and thermal and mechanical processing. Other properties such as fatigue behavior, corrosion resistance, impact properties, etc., are beyond the scope of this document and responsibility for ensuring the acceptability of the product for applications where conditions warrant consideration of these other properties must be borne by the end user.
Product Status: In Stock
File Size: 134K
Deliver   List $  Member $
Mail      $59.00  $47.20
Fax       $59.00  $47.20
Download  $59.00  $47.20
RE: Grade 8 bolts
Thank you very much!
