Uf clone functions call question
Hi is someone know in which order to call the uf cloning functions.
I know the order of the first and last but between I don't.
Thank you in advanced.
ufs.Clone.Terminate()
ufs.Clone.Initialise(UFClone.OperationClass.ImportOperation)
ufs.Clone.SetFamilyTreatment(UFClone.FamilyTreatment.StripFamilyStatus)
ufs.Clone.setDefNaming(UFClone.NamingTechnique.Autogen)
ufs.Clone.SetDefDirectory(pathsave)
ufs.Clone.SetDefAction(UFClone.Action.Overwrite)
ufs.Clone.SetLogfile(pathsave + "clone.txt")
ufs.Clone.SetDefAssocFileCopy (False)
ufs.Clone.SetDefFolder (user_name + ":" + import_folder)
Dim di As New IO.DirectoryInfo(pathsave)
Dim lFiles As IO.FileInfo() = di.GetFiles("*.prt")
Dim fi As System.IO.FileSystemInfo
Dim foundfile As IO.FileInfo
' get the files in the directory
For Each foundFile In lFiles
OS_FileName = foundFile.name.Remove(foundFile.name.Length - 4, 4)
ufs.Clone.AddAssembly(pathsave + foundfile.name, load_status)
ufs.Clone.AddPart(pathsave + foundfile.name)
ufs.Clone.setNaming(foundFile.name, UFClone.NamingTechnique.Autogen, OS_FileName)
ufs.Clone.SetPdmDesc(foundfile.name, OS_FileName)
ufs.Clone.SetPdmName(foundfile.name, OS_FileName)
ufs.Clone.SetAssocFileCopy (foundfile.name, False)
Next
Dim naming_failures As UFClone.NamingFailures = Nothing
ufs.Clone.setdryrun (false)
ufs.Clone.GenerateReport()
ufs.Clone.PerformClone (naming_failures)
RE: Uf clone functions call question
I need to know it the in between functions call order is important.
The above example was taken from this link
http://www.eng-tips.com/viewthread.cfm?qid=378131
and copied here for convantion
CODE -->
cschnei (Industrial)
29 Apr 15 07:22
Hello Alex,
 I think you forgot to initialise the clone operation. Here is a snippet of the code I use to import all parts of a selected OS Folder to a specified Teamcenter folder:
 Next
 I hope this helps.
 Carsten
