Node orientation for beams
We are working on an addon for Ansys 18.2 that will check structure according to standard.
For AISC360-10 check we need to have beam orientation. Currently, we read this info from orientation node.
My question is:
Is it possible that orientation node is missing and beam orientation is defined by another method? If yes, how it can be done?
I appreciate any tips or links to articles because we use Ansys only for few months (we have more experience with Femap and NX/Simcenter).
Yarko
RE: Node orientation for beams
per the MAPDL Element Manual, if no orientation K node is defined, the element Y axis is parallel to the global X-Y plane. If the element is parallel to the global Z axis, the element Y axis is parallel to the global Y axis.
Rick Fischer
Principal Engineer
Argonne National Laboratory
Rick, thank you very much for the advice!
