Estimating gallons of H20 per cubic yard
Is there a table or formula available to better estimate how many gallons of water it may take to raise the moisture content of existing soils during compaction?
RE: Estimating gallons of H20 per cubic yard
Say optimim moisture content is 12% and soils are at 8%, and maximum dry unit weight is 110 lbs/cufic foot. You need to increase moisture by (12%-8%)x110 or 4.4 lbs/cubic foot. Since there are about 8.34 lbs/gallon, you need 4.4/8.34=0.53 gallons/cf. This is per cubic foot at 100% compaction; you would need to factor lower by in place density divided by max dry density.
I guess what I am saying is that adding the water is not a precise science, therefore you may be expending a whole lot of time in determining this calculation when in reality, it will be about as useful to the contractor as knowing the actual number of 3/4" rock in a 4-20 sample. The importance is the application and satisfaction of the specification, or the end result. I suppose it makes for an interesting exercise in theory.
KRS Services
www.krs-services.com
