Identify partially visible edges in 2D Drawing using NXOpen?
Hello Everyone,
I have been struggling with this the entire day. Is there any NXOpen API that provides if an edge is partially visible in 2D Drawing? I have been looking at 2 API's AskVdeData and UFSo.AskVisibilityOpt but none of them tells me if an edge is partially visible. There is no View Dependent Edit done on these edges. I also need to find out the region of visibility for partially visible edges, so that I can do a callout to the visible section of these edges. Any suggestion?
I would really appreciate your help.
Thank you,
Amitabh
Thank you,
Amitabh
RE: Identify partially visible edges in 2D Drawing using NXOpen?
Thank you,
Amitabh
Amitabh
