Blind Bolts for use on Aluminum Square Tubing
I am working on small aluminum access platforms. Given they heavy strength loss due to welding, I am curious about using a blind bolt to connect either double angles or a WT to a square tube column for the floor beams and knee bracing.
I see Magna-lok and hollo-bolt have 316stainless options, but I have never used them in design. If anyone has detailed similar connections I would appreciate your advice.
Tom
Tom
RE: Blind Bolts for use on Aluminum Square Tubing
Huck bolts, "Jo" bolts, how about Cherry (blind, "pop") rivets ??
There are also "riv-nuts" ... a one side (ie blind) installation that provides a thread for a standard screw.
I'd've thought you could rent the tools required.
