ANSYS APDL
ANSYS APDL
ANSYS APDL
Hi All,
I am new to ansys apdl and am not familiar with the coding. I know I am not doing this right.
Can someone help me with this code. I am trying to write x, y and z displacements to arrays dx, dy and dz
I appreciate your help!
Thank you,
Dipak
/post1
*cfopen,D:\documents\crank3.txt !Open output text file in a directory
*vwrite
CRANK,dx,dy,dz,ncount
! Selects a subset of components and assemblies (a new set, whose name is crank)
!set,3,1
cmsel,s,crank
nsle,s ! Select a set
*GET,nmax,NODE,0,num,max ! get highest node number in selected body
*GET,nmin,NODE,0,num,min ! get lowest node number in selected body
ncount=nmax-nmin+1
*DIM,dx,ARRAY,nmax
*DIM,dy,ARRAY,nmax
*DIM,dz,ARRAY,nmax
!Loop for all nodes (nmin to nmax with increment of 1000) in selected set
*do,i,nmin,nmax,1000
set,3,1
dx(i)=ux(i)
dy(i)=uy(i)
dz(i)=uz(i)
*vwrite
CRANK1,dx,dy,dz,ncount
*vwrite,dx(i),dy(i),dz(i),ncount
%15.5e,%15.5e,%15.5e,%8.0f
!*enddo
RE: ANSYS APDL
Dont use loops for something like this. They are slow, boring, unsophisticated, and people will think you are an amateur. Use vector commands instead. Also, what you are doing will only work if the selected nodes are continuously numbered. Try something more like this:
nsele=ndinqr(0,13)
*dim,ddata,,nsele,4
ncount=ndinqr(0,14)
*dim,ndata,,ncount,10
cmsel,s,crank
nsle,s
*vget,ndata(1,10),node,0,nsel
*vfill,ndata(1,1),ramp,1,1
*vget,ndata(1,2),node,1,u,x
*vget,ndata(1,3),node,1,u,y
*vget,ndata(1,4),node,1,u,z
*do,j,1,3
*vmask,ndata(1,10)
*vfun,ddata(1,j),compress,ndata(1,j)
*enddo
*cfopen....
*write,ddata(1,1),ddata(1,2),ddata(1,3),ddata(1,4)
%15.5e......
Rick Fischer
Principal Engineer
Argonne National Laboratory
RE: ANSYS APDL
Rick,
That was quick.
I struggled for few days to get info on ANSYS APDL which is scarce (except for the help in mechanical) more particularly on sample examples/tutorials. Coding and syntax is little different than FORTRAN....I think.
I will implement your suggestions in my bigger program where I use displacements and velocities for further computations.
Today I learned few things from you.
I really appreciate your timely help.
With Best Regards,
- Dipak
RE: ANSYS APDL
APDL is considered archaic by the new guard at Ansys Inc. Power users embrace it because it is immensely powerful. Good sources for APDL tips and macros are the websites of the various Ansys distributors, and Sheldon's Ansys.net.
Rick Fischer
Principal Engineer
RE: ANSYS APDL
I wrote the following code based on the previous posts.
node_count = ndinqr(0,14)
*dim,node_id,array,node_count,2
*vget,node_id(1,1),node,1,nlist
cmsel,s,face1
*vget,node_id(1,2),node,0,nsel
*cfopen,nodes.txt
*vmask,node_id(1,2)
*vwrite,node_id(1,1)
%15.5e
*cfclose
face1 is a face named selection. This code writes a text file containing the selected nodes on a column. I would like to modify it
so that the node ids are written in this format:
1,2,3,...
Any tips?
