Precast Wall Panel Diaphragm Connection
I have a single story warehouse with precast insulated wall panels and a joist/joist girder system in the US.
Im looking for insight on developing the connection to the panels acting as shearwalls, but otherwise non-load bearing.
My joist spans immediately adjacent to wall are 75 feet long which leads to large deflections.
If you have experience with these structures, is it common to connect with a slotted connection in the perimeter edge angle? Is their a detail you could share?
Should we limit deflection in the joist along the wall to a small amount, rather than L/240?
RE: Precast Wall Panel Diaphragm Connection
A slot works nicely but you can have issues with where the bolt ends up in the slot. You need to make sure the bolt ends up in the top of the slot (or make the slot very large, which is not that practical) and you also need to make sure that continues along the length of the truss. It's no good if some bolts are right and others are wrong, the load will go wherever it can.
I also have some doubts about how "slippery" that slotted connection really is. If it's important, I make sure to indicate not to tighten the nut or maybe even add a teflon washer.
Sometimes that's tough when you're also relying on the wall/deck connection for out-of-plane anchorage of the wall.
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
If the slip connection must be had, you might try welding a PSA strap/insert anchor to the top of the joist and inserting into a female bit cast into the precast shear wall. I've got that on a project right now where the roof is hollow core rather than joists. It's a reliable way to both get vertical slip and maintain shear transfer.
