Any way to make different views on a drawing show different reference sets?
Working on some very flexible tubes. For our production plant, they get a flat view where it's just a straight tube with all the clips and such on it. The assembly plant however needs a view in the installed position. So in the 3D data, all of this is done in one part instead of as an assembly... (don't ask, I am not allowed to just make them an assembly for some reason). So I'm stuck trying to figure out a way to do these drawings more efficiently. Currently I am making the views and just using "view dependent edit" to erase all the bodies out. I have reference sets already for the Flat part and the Installed part. Is there some option I'm overlooking possible for being able to link my reference sets to that view so I can just quickly change bodies around via reference set instead of having to do view dependent edits all the time? Or maybe you have a different solution... but doing it this way is just awful. If i could put it all into an assembly, I'd just have "flat" and "3D" as an assembly and it's a quick toggle during view creation, but since I'm working in the customers teamcenter, I have to follow their data structure and am not allowed to do assemblies.
RE: Any way to make different views on a drawing show different reference sets?
Now, if you're talking about sheet metal where you have a 3D solid model and a 2D flat pattern, if you created the model using NX Sheet Metal and then created the Flat Pattern using those same tools, all you have to do is create a normal drawing of the 3D model and then ADD the 'Drawing view' that the Sheet Metal module automatically created when it created the Flat Pattern showing only the 2D curve layout.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Now in your master drawing add your same component twice, or the number of different reference sets you have. Then set each of these components to a different reference sets.
Now create arrangements in your master drafting of the different components per the reference sets.
Now you can create your base views of the different arrangements.
What version of NX do you have? I was going to upload a test example.
I will have to give your method a shot though SDETER, that sounds like it might be possible to do. I'm in NX11, however I understand what you're saying, so you wouldn't have to go the extra method to give me an example. I already have the reference sets created, so I'll have to just duplicate the part and try that method out.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Give each solid body it's own unique layer and use "Layer Visible in View" to filter out what you don't want to see in each view.
Done.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
Dave
NX9, Win 7 Pro SP1
