Interaction steel-mortar tensile test (Lap Splice test)
After the laboratory tests, with MTS (tensile test), I would like to model SRG (Steel reinforced ground) with every single steel wire, so as to study how the transmission of the stresses depends by the anchoring length of two differents layers of Steel. Modeling SRG as single strands (solid element in Abaqus) how can I model their interaction with the mortar? The best way is to create a ''bond-slip realation'' between the surface of the wires (solid in abaqus) and the surface of the mortar in the Interaction module of Abaqus?
Thank you in advance
