Measure between
3
Measure between
Measure between
How to measure two geometries in specified direction.
RE: Measure between
Select the first geometry that has already a direction, then select the other one (for instance, select a plan and then the other geometry. The first selection would choose the direction).
CAD 2015
RE: Measure between
that would work if you looking for min distance from A to B, now if you're looking for distance (A,B) along direction, you might need to use Distance Analysis Tools from FSS workbench as you can define the orientation of the analysis from the compass
Eric N.
RE: Measure between
Even for that specific license required thumbsdown. Drawing is the way to go.
Jenia Ladkov
RE: Measure between
Quote (Select the first geometry that has already a direction, then select the other one (for instance, select a plan and then the other geometry. The first selection would choose the direction). )
How to do this when I want distance between 2 points?
RE: Measure between
that would be the components... using measure between, press customize and tick Components in panel and 3D columns.
if you need a different coordinate system, choose one in the "other Axis" tick box enabled field
regards,
LWolf
RE: Measure between
Quote (How to do this when I want distance between 2 points?)
Simple: select the first point, then the other!bigsmile
CAD 2015
