Calculation of the equivalent RLC Circuit of Connected Flat Cables
I have some connected flat cables connected together in series and parallel. What software should be used to get the equivalent RLC parameters of this circuit?
RE: Calculation of the equivalent RLC Circuit of Connected Flat Cables
At first you have to state what kind of flat cable you need. On the web there are 20,000 types. See attached an example:
http://www.molex.com/pdm_docs/sd/250010802_sd.pdf
Second you have to know what are the currents, number of wire, phase order and so on.
