Noise is not the same in both direction
A couple of month ago I started a topic concerning a set of a small pinion and an internal gear assembles in parallel axis. I had to explore many setting in order to reduce noise. There is almost no load to transfert.
Choice was to use plastic internal gear so I made one in 6061 and another one in plastic. The other choice was to explore the helical type of gear set. I designed and ordered straight and helical gears in both plastic, stainless and 6061 to explore all possibilities.
I have in my hand all gears excepts the internal helical gears. I installed the straight set made of a stainless pinion (12 teeth 48 dp offset of 50%) and the internal gear (244 teeth, no offset) made of 6061 (I have one in plastic too).
The strange thing is that the noise is different if I move by hand the gears in one or the other direction. What can be the cause? Is it possible that the cutter do not do the same quality in both face of each teeth?
Robin
Robin
RE: Noise is not the same in both direction
I would suspect that the intenal gear
was not generated but gashed with a milling
type cutter and may be slightly off spec.
Was is cut with a shaper cutter ie. generated?
Sounds like an interesting phenomenom.
The ABA-PGT tooth form, from the company of the same name, allows for tip relief, which helps reduce the effects of load deflection in plastic gears. It also helps reduce noise after the gears have developed a permanent deformation in one direction. I have measured several degrees of lean of plastic gears after running durability cycles.
I installed the set with a plastic internal gear and started a run to see if I could have any break-in effect that would reduce noise. I'll do the same thing with the aluminum internal gear which is really noisier than the plastic one. Maybe the break-in effect will polish the surface finish and help reducing noise.
Robin
Mech eng.
run it in both directions to see if the
noise reverses itself? Or is it possible to
turn the gear over and test this condition?
Just trying to get some quick answers.
My thinking is if you do one of the above,
you may be able to isolate which part is out
of spec.
I'm not sure the plastic unit is off spec since it sounds quiet for me. At least as quiet as can be a gear set. For the aluminum parts, I'm not sure if the sound is still normal but I want to give the systema break-in period to see if noise will go quieter.
Diamondjim, remember the spec I sent you about the helical set, I have the pinion in my hand and I ordered the special tooling to cut the internal gears, I should have them for march I guess. I really don't know if the helical set will be quieter than the straight set for the plastic material. It sounds already quite quiet.
Robin
Robin
What you said make sense but I did not know that it can make a practical difference in moise and life. By having an even and uneven number of teeth in gears, you alternate the mesh pair of toth on pinion and gear. In this way, you wear the teethin a more equal pattern, avoiding repeating wear at specific spot.
I don't have any load so life is not a problem but noise is a big one.
I am waiting an internal helecal gear and by luck the teeth ratio is 12/213:)
Robin
The gear set was initially designed
to have the pinion drive and therefore
it was recommended to have a long addendum
on the pinion to make the disign similar
to a recess action gear set. When the gear
is driving, you have more approach action,
and can expect more noise. I did not realize
you would be using the gear to drive the
pinions.
Any gear which runs at a speed morethan 100 RPM, need to be profile ground.Cut gears profile has the error.When u mesh two gears , theoretically speaking it should mesh at its pich circle dia.normal cut gears will have more variation. So you have to necessarily go for profile grinding operation.Its not just due to surface finish. To have better surface finish u can go for polishing after gera cutting operation.That never reduce noice. So Please go for profile grinding operation and iam sure u will not face this problem again.
ok
Sudev Nair
Probably this fact is explaining why I have less sound when driving the system by the pinion than when driving by the gear. This does not explain why the sound is not symetrical but the explanation of the non symetrical cutting could be the one for this part.
The system is a lot less noisy with the plastic gear (Ertalyte) than with the alu (6061-T6).
Sudev, since I'm using palstic gear, can I still go to a grinding operation? Furthermore, the gears are quite small (48dp, 12 and 244 teeth). The internal gear is running at 60 rpm.
I could profile ground and polish the 6061-T6 gear but it is maybe less expensive to just use the plastic gear.
I'l have to work on this since primary test was done in open loop type control and the closed loop os noisier.
Robin
Sorry, I thought you were talking about Metallic gear. Of course I didnt go thru the material u have used.
Can I ask you a fundemental question now? You might have already calculated this. But still I would like to clarify.
Did you calculate the number of teeth required on Pinion under interfernce criteria. When nr of teeth is less as per this criteria, there will be a interference between pinion and gear. I understand that u have 244 teeth in gear and 12 teeth in the pinion.Without calculating itself i feel this will interfere and it will eat material from the root of the pinion too.
So please calculate nr of teeth required based on this criteria. If you want my help pls give me details like nr of teeth in gear(just confirm), module, and like in pinion also. I faced similar situation with metallic gear.Then I calculated for interfernce and decided to go for minimum teeth required for Pinion and solved the problem.One intersting thing is that, its not possible to have a huge redution with spur or helical gear assembly.If you need very high reduction you may have to go for nr of stages of reduction say 3-4 reduction stage.This all due to min nr of teeth required on pinion.One stage you need very high reduction you may have to go for worm and worm wheel or planetary gear train design.As per your gear train you get a reduction of 244/12 ~ 20 reduction one stage itself.I feel its too big..so pls calculate min nr of gear teeth required for pinion.
I dont thing its due to gear shaping problem.Even you can go for plastic injection molded gears(high precision and readily available in market). Also check the center distance and tolerance allowable for center distance variation..okkk
Pls let me know your resonse on my statement
Sudev Nair
I do not have any place to have multistage and I'm under tight backlash control. I cannot use injected gear since I need really special internal gear (shape, number of teeth)
Just a simple question: If I do not have undercutting and pointing tips, can I still have interference?
If yes, what are the formulas to calculate it?
Robin
Mech eng.
Robin,
Please be assured that the aluminum gear
will always be noisier than the plastic
gear. If you can imagine the two part
slapping against each other, the steel
against plastic verses steel against
aluminum, it should be obvious that the
plastic causes less noise.
I am anxious to see the results of the
helical set. Except for strength, the
plastic will probably be your best bet
as the steel and aluminum mesh will wear
quite quickly from other designs that I
have seen. I do not know if you can coat
the aluminum with a coating to make it
less porous at the surface to help reduce
the wear.
Gary at Gear Manufacturing, Inc.
Just my 2 cents
Ralph
I have the noise with the straight gear set. I haven't received the helical internal gear yet but should be in a couple of day. I just found one place in north america that can cut it! I've asked around 25 places!
Diamondjim, As you said, the plastic set is quieter and I'm happy to have another (other than me!) that think wear will be less with the plastic set. We will go for the plastic set with ss pinion for sure.
I can see small burrs on the profile where the cutter exited. The noise is at the pinion frequency and the slip ratio at sap for the pinion is 2.67, which is quite high.
How can I modify the tip to lower noise?
Is it expensive and complicated to measure if the gear if off spec and by how much? How do they do that with a 48 pitch diameter gear? it is small?
Hum, puzzled by this noise...
Robin
The slip ratio is not that high,
anytime the gear od approaches near
the base diameter the ratio get high.
I have seen 14 and the gears seem to
mesh well in slow applications.
Just decrease the od of the gear by
a small amount and see how quickly this
ratio changes.
These are such small gears that you
could probably deburr by hand with
a diamond emery board to see if that is
the source of the noise. You might try
running it in at a slow rpm for an hour or
so and gradually increase the rpms.
Best analysis is by single flank testing, or analytical inspection.
