Slip Critical Connections AISC 14th edition
For slip critical connection there is a ns value.
ns=number of slip planes required to permit the connection to slip
Can anyone provide me with an example where there would be TWO slip planes required to permit the connection to slip?
RE: Slip Critical Connections AISC 14th edition
3 ply connection = 2 slip planes
...a gusset plate with a diagonal bracing angle on each face?
Dik
Thank you both for responding. So if the bolt is in double shear then it has two slip planes?
Correct
