Relay test
Relay test
Relay test
Hello everyone, someone knows a relay test equipment with a frequency range of up to 800hz. I only know the Amperis that up to 1000Hz, but the resolution is too low. only 0.001 Hz and I need a bit more resolution and more accuracy (Prtective relay test equipment of Amperis Accuracy <0.14% reading + 0.06% range guaranteed).
Thank you!
