Drawing color standard for dimensions?
Is there a standard for the color of dimensions on drawings? I have always used black for my dimensions, but recently we have been looking at using blue dimensions. I was curious if there is a standard practice for this, nothing in Y14.5 2009 that I could find.
RE: Drawing color standard for dimensions?
Other than that it's up to whoever pays the bills or feels like they are in charge. I worked with a bunch who were so lazy they set all linewidths to .005, making them difficult to see, because they had already committed a bunch of drawings on a program that and decided to be 'consistent' rather than use ASME suggested line weights (in other words, hide their incompetence and hope the customer didn't notice.)
The problem with color hard copy is it may be reproduced on something that is monochrome and some colors will not reproduce well.
Don't assume that the person who receives your drawing has a colour printer. A lot of colours render as semi-legible half tones on black and white printers.
JHG
There is a 2014 version
That is because the old diazo reproduction machines mostly did one colour only.
JHG
ASME Y14.41-2012 "Digital Produce Definition Data Practices" invokes Y14.2 for Annotation Legibility. A dimension line apparently being an "annotation" in the context of Y14.41.
In my mind, if there was an ASME standard for dimension line color it should be found in one of those two documents.
It is not.
Chris, CSWP
SolidWorks '17
ctophers home
SolidWorks Legion
B.E.
You are judged not by what you know, but by what you can do.
