Straps required on rebar bundles
HI,
How to calculate the straps required?
I trying to find the number of straps required for Rebar bundles(circular) ,which changes in length with a standard 2 T weight.
the strap strength is 22 KN -notching or clamping strength is 70 to 80% of the designed strap strength i.e..17.2 ~18.4 KN.
Ex: for a 2T bundle which is 18M in length-how many straps does it need for safe handling.
RE: Straps required on rebar bundles
Is that 2 tons weight? (Metric, standard, US?)
Are you asking about the straps for lifting for construction/installation?
Dik
