Search publication elements in part
Is there a way to search&select only elements that are also published through VBA script?
Thank you!
RE: Search publication elements in part
Yes, you can access publications and what they reference.
MyPart and k+1 are my own definitions, but the syntax is as follows
PubName = MyPart.Parent.Product.Publications.Item(k + 1).name
Set PubRef = MyPart.Parent.Product.Publications.Item(PubName).Valuation
regards,
LWolf
Thanks for reply but I would like to search only published features inside a part. For example: only search (inside a part) all planes that are publicated...
Best regards,
Rajko
You need to be more specific on what you are looking for.
try to use this:
CODE -->
Dim publications1 = Part1.Publications
            Num_publications = publications1.Count
            For b = 1 To Num_publications
                Dim publication1 = publications1.Item(b)
                Dim pubRef As Reference
                Dim PubName As String = Left(publication1.Name, 4)
                Dim Publication = publication1.name
               Next
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
