Disturbing Frequency...Help ...Mil-std-810 516.5 Ground equipment shock
Thank you for your upcoming help ^.^
I am working on electronic enclusore and it should servive in Mil-std-810 516.5 Ground equipment shock.
to select the right isolater ((Disturbing Frequency)) should be known.
Is there any recommended (Disturbing Frequency) could be found related to (Mil-std-810 516.5 Ground equipment).
RE: Disturbing Frequency...Help ...Mil-std-810 516.5 Ground equipment shock
How is this different that your other, related, question? An 11-ms 40-g sawtooth is already specified by your referenced table 516.5-II
TTFN (ta ta for now)
can i calculate it like this:
V=0.5 * 11ms * 40g * 9.81
Then Kinetic energy in the pulse = 0.5 * V'2 * mass ??
By mentioned table I have the peak acceleration (P=40g) and the nominal time (T=11ms).
now I did:
calculate the velocity of the pulse V=0.5TP.
-we have the total Mass (m)
k(Spring coefficient)=(v'2 * mass)/(e'2 * D'2(maximum displacement))
so we have k and D.
