HYDRO TEST AFTER NOZZLE REPLACE TO NEW VESSEL
Dear All,
Greetings
I have one question. Please help me to solve this issue. Now we are in project - construction phase. We received small pressure vessel from long time. It is re-heat condensate drum. Now we observed it has wrong nozzles ( mean the nozzles came from non-approved supplier ). Contractor start to cut and already they purchased new nozzles from approved supplier. They want to put them and perform welding. What type of tests I should ask them after repairing or alteration? Only DPT or Hydro test also ? Please I need the answer according to international standard.
Note: It is ASME stamped (U)
Thanks and my special appreciation for all of you
Greetings
RE: HYDRO TEST AFTER NOZZLE REPLACE TO NEW VESSEL
Either the National Board Inspection Code or API 510 would be the international codes to follow, and they contain the necessary requirements. I would recommend a wet florescent MT and liquid pressure test - not a construction code hydrostatic test.
My appreciations
