doubt - autoit recording
Hi, i use autoit recorder to record the mouse clicks. i just want to record how to automatically open notepad.. the procedure i followed is uploaded as a video. when i run the .au3 file, the windows key gets activated and then the 'notepad' is not getting typed and in the taskbar, the script appears paused after this- what could be the reason. thanks
http://files.engineering.com/getfile.aspx?folder=3...
