Point Creation
Point Creation
hello everyone,
I am having a hard time creating points in Ansys Fluent in order to do some readings at that point.
I go to Surface - Creat - Point. When i introduce my points coordinates, some work, another don´t. I am sure that those coordinates exist (i used probe to double check). Even when I use Select Point with Mouse Function, i can´t create the point.
The error that shows up is "Error: Surface creation failed!; Error Object: #f".
Any ideas ?
Thank you in advance
Any ideas ?
