api 6a valve material
As mentioned the requirment of materials for equipment in standard and non standard material table(table no 5) body and bonnet can be 36 up to 75K for example in 5000 class but also indicated that integral end connection flanged shall be only 60,75K,
So if we want to select valve with flanged end and manufacture by forging or casting integrally, we have to use 60K for body and bonnet too, or flanges are from the body parts and can use 36K for 5000 and blow classes??
RE: api 6a valve material
When you specify a valve with integrated flanges, the body, bonnet and flanges will be forged/cast from the same material. So you follow one material strength but when you produce the flange to be a weld neck type, API 6A allows you to use two different strength materials.
In general, in piping industry, the flange strengths are usually kept higher due to higher bending stress involved.
Ganga D. Deka, P. Eng
Canada
In my opinion, the whole parts of flanged valve are known as body and bonnet , so 36k material is accepted for this usage.
The concern is to see in holistic approach before we choose what material designation to use.
Let's say the valve body can be configured by using two material designation, i.e. 36K for flanges and 60K for valve body.
Based on load consideration, I don't think its a good idea to mix lower and higher strength.
Given it happens that way, 36K material shall be the weakest area when the whole area was subjected to uniform load during operational service.
Table 5 of API 6A 20th Ed inherently suggest us to use 60K minimum for valve flanged,
since it consists of "body" and "flanged - integral end connection"
