heat expansion
heat expansion
How does heat expansion work?
I'm interested in how metal will bend either away or towards heat.
What if you heat just a little section of metal with heat (not hot enough to melt, just expand), and keep the rest at normal temperature, what will happen to the heated part? My idea is that it will expand and form a little bump in the metal.
RE: heat expansion
