Brass Design Code
Brass Design Code
Brass Design Code
Is there specific design code on British standard for Brass material?
RE: Brass Design Code
I wasn't aware there were any, but, code could address strength as well as corrosion issues. There may be some naval publications.
Dik
You might try contacting some of the suppliers of the item(s) in question, they would likely be the ones to know.
