Pressure Hidrostatic vs admissible pressure
can the hydrostatic test pressure be greater than the admissible pressure?
RE: Pressure Hidrostatic vs admissible pressure
What do you mean by admissible pressure?
Not sure what admissible pressure is either, but check out 345.4.2(d) if using B31.3.
Without any further information then the safe answer is NO.
Answer the questions above and give some details, numbers, design codes etc and we might get somewhere.
