Wrap a sketch onto a surface
I'm looking to wrap a sketch onto a surface to so that it retains it's dimensional constraints. ie if I sketch 5 lines with 1mm spacing and project onto a curved surface it should retain 1mm spacing. Right now the project command is just doing the same as extruding the sketch through the surface and giving me the intersection.
Any help is appreciated,
RE: Wrap a sketch onto a surface
check GSD Develop function
Eric N.
