3D construct
3D construct
Hello
can someone please tell you what to start with to construct a Kids Bike Traile Linkas 3D.
it should select material and geometry.
I think I should start sketching with forces (children's weight)! and type of load (whether it is tensile, compressive or torsional), then select the appropriate material for it.
Am I on the right way?
Thank you for the help
RE: 3D construct
After that, I'd anticipate your design will be driven by stability and deflections/stiffness -- both driven mostly by your geometry.
RE: 3D construct
According to the project, it is not the economic aspect that comes first and foremost, but lightweight construction.
and the model must be made of at least 90% wood.
RE: 3D construct
RE: 3D construct
But where should one start?
free body diagram
RE: 3D construct
RE: 3D construct
I would first design a rough model and then do FEM analysis to check the stresses and deformations.
