PLMXML export data not able to open in NX
Hello All,
I have extracted Teamcenter data using the command line in Linux options as below:
./plmxml_export –u=xxxx -p=xxxx -g=dba - class=ItemRevision -export_bom=yes -transfermode=xxxx -xml_file=/volumes/Teamcenter_extracts/WholeExtraction.xml -log=/ volumes/Teamcenter_extracts/WholeExtraction.log
All the part files are extracted into a single folder. When I open the assembly file it throws the error message "Failed to find File using current search Options, part left unloaded".
I checked with all the load options "From Folder/As Saved/Search Directories", But got same error message.
Kindly throw some light to fix the issue.
basenxuser
basenxuser
