Need technical terminology
Hello All!
I'm seeking the proper name for these little centerline ends (tails). In following the precedence of lines, while creating multiple views, we align them .125 out from the endpoint of the line representing an edge (visible or hidden) and ,25 long.
RE: Need technical terminology
ponyflyer,
Do you have a picture?
JHG
If I'm understanding correctly
The cross at the middle is the "mark"
then you have a "gap"
then the "extension"
... then a gap then a "dash"...
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
