structural steels for pressure vessels
hi all
Do you know where i can find a definition for "structural steel" ?
Is the construction of pressure vessels with "structural steel" is covered by interpretation of the ASME BPVC code ?
thank you
regards
thank you
regards
RE: structural steels for pressure vessels
They should not be used for pressure vessels, you need "P" steels for this application (eg. P355).
Can't say for sure in ASME, however seen the large differences between Structural and Pressure steels (mainly in testing the mechanical properties), I doubt they are interchangeable in other countries...
http://be.linkedin.com/in/fusionpoint
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
