softening or annealing sae 9260
Hi all.
I have a few cold drawn sae 9260 round bar , size from 7/16" (11,11 mm) to 3/4" (19,05 mm) and I need to  down its hardeness to less than 190 brinnel.
What could be the appropiate heat treatment .?
The pourpouse of this treatment is to allow a cold drawn reduction to get smaller diameter.
The material will be used to make car suspension springs, it will hardendened after coiling .
This the chemical composition
Component
Carbon, C    0.56    0.64
Iron, Fe    96
Manganese, Mn    0.88
Phosphorous, P                0.035
Sulfur, S                0.04
Silicon, Si                2
Thanks in advance
Pardal
RE: softening or annealing sae 9260
You can anneal it down to around 260 BHN-use around 1575 deg F.  I don't think you'll get the hardness below that.
9260 that has been speroidized annealed can have hardness as low as ~ 184 HB.  To spheroidize anneal, you can do two things:
1) heat to 760 °C (1400 °F) then cool to 705 °C (1300 °F) at a rate not to exceed 6 °C (10 °F) per hour.
or
2) heat to 760 °C then cool rapidly to 665 °C (1230 °F) and hold for 10 hours.
Since you are looking for the low end of possible hardness, you may need to use slightly longer times at temperature.
thanks for it boys.
have a happy week end
Pardal
Pardal
pardal,
I'm not sure if you already know this, but using SAE 9260 with 0.04% Sulfur for an automotive suspension spring is not a good idea.  This level of Sulfur will result in many sulfide inclusions which greatly reduce the fatigue strength.  Typical Sulfur levels from true spring steels are more like 0.008%.
Hi tpv .
This composition was token from a data sheet, not from a chemical analysis.
I will check it .
Thanks for the tip.
Pardal
