Workbench solution combination
Is there a way in Workbench to input many solution
combination coefficients efficiently?
For example if one solution combination consists of 12 load cases
and there are >10 solution combinations which have to be calculated.
RE: Workbench solution combination
If all load cases are linear, just Right Mouse on Model > Insert > Solution Combination. Then Add to set your coefficients for each basic case. You can then copy the Solution Combination and go into it to edit coefficients as required.
David
I have a list of coefficients (altogether >100 values) for different combinations which I got from other software.
The other way round this would be to set up all the combined load cases and use Parameters to input the factored loads to each. Parameters can be read in from your external data.
David
Kind regards,
Jason
