Dissimlar Meshing of Congruent Surfaces
Using Patran, I am experimenting with "Glueing" mismatched meshes.
Consider a 2D situation with 2 independent pairs of rectangular surfaces.
One pair (A) with a single common edge of the dissimilar length.
Method of surface generation was using a surface vector.
The other pair (B) with a common edge of same length, but each surface was generated
with their own set of points & curves, ie 2 points and 1 curve coincident at the common edge.
See Congruent_Meshes - Surfaces.
Mesh (A) left hand (LH) surface with Quad4 with Global Edge Length 1.
Mesh (A) right hand (RH) surface with Quad4 with Global Edge Length 0.4.
Meshes as expected.
Mesh (B) LH surface with Quad4 with Global Edge Length 1.
Mesh (B) RH surface with Quad4 with Global Edge Length 0.4.
Meshes not as expected.
See Congruent_Meshes - Meshes.
I have not found a method to get a 0.4 length rectangular mesh on the (B) RH surface.
The RH side is always influenced by the LH side mesh.
Generating B with 2 surface vectors or adding a mesh seed to the RH surface on LH side edge curve has no effect.
From Patran 2010 - Reference Manual Part 2: Geometry Modeling, page 14
Topological Congruency and Meshing
For a group of surfaces or solids to be congruent, the adjacent surfaces or solids must share common edges,
as well as common vertices.
MSC.Software Corporation’s Patran software product required adjacent surfaces
or solids to share only the common vertices to be considered topologically congruent for meshing).
I see this as saying if common (coincident) points (as is the case in B) are used to define 2 surfaces, the surfaces are automatically congruent.
Anybody know how to get the meshes I require?
Any suggestions would be appreciated.
Meshes as expected.
RE: Dissimlar Meshing of Congruent Surfaces
Specifically, go to the Geometry menu and use Action: Disassociate, Object: Curve. Surfaces may be created using explicit curves or virtual curves (for example, a virtual curve going from point P to point Q, where an explicit curve is never generated). As you generated the surface from curves, you may need to disassociate both curve and surface edge. So in the Curve List dialogue, first try using "curve 5" (without quotes) and if that does not work, try "surface 4.x" where x will be the number 1,2,3 or 4 depending on the surface topology.
Once the edge of the meshable surface is disassociated, you can mesh it with impunity.
Another method we use to do this when sometimes the geometry does not want to disassociate (because other geometry depends upon it) is to create a duplicate surface at the same location as the original surface. To do this, simply use Action: Transform, Object: Surface, Method: Translate and enter <0,0,0> in the Direction Vector dialogue, and pick the surface to duplicate (surface 4 in your case).
Cheers.
