Painting Repair on Hot Pipeline surface
I am looking for answer , if I have to choose a paint for repair on flow line which is already in Service with high Surface Temperature (around 90 deg. C).Is Intertherm228HS is a good option Or not.
Do Flash Point of Intertherm228HS arouse any safety concern for Hot pipeline to be painted.
RE: Painting Repair on Hot Pipeline surface
It is against posting policies to double post. You may want to flag one of your posts and have it removed. Considering your question is paint related, I would leave the question in the paint forum and remove the one in B&PV.
DGrayPPD
"Tell me and I forget. Teach me and I remember. Involve me and I learn."
- Benjamin Franklin
Not to encourage the practice, but, if I'm not sure an unusual question will be reviewed in one forum, I'll occasionally post it in a couple of forums. If I see a question that has been posted in two forums, if I'm able to, I'll at least try to answer it in one of them.
Dik
Thanks for answering and giving alternate Painting option .
Dik
If you're already looking to use Intertherm check with AkzoNobel regarding their other product lines, maybe one can solve your problem.
Ehzin
