goose connections
goose connections
Hello! I need your help. Can anyone show an example of circuit diagram where used goose protocol for connection between 2 terminals of relay protection? How can I depict connections between terminals on a circuit diagram?
RE: goose connections
2. With a black or colored line.
Mike Halloran
Pembroke Pines, FL, USA
http://www.pes-psrc.org/Reports/IEEE_I5_Schematic_...
May be somebody else to connect to discuss and share information.
As suggested, you
justneed another 'linetype'.... but that highlights the complexity and difficulty of representing multiple communication/control modes and potential interactions without degrading understanding of the controlled system.
Mike Halloran
Effectively documenting the design is one of the challenges associated with implementing GOOSE-based protection and control schemes. With GOOSE messaging being a relatively unfamiliar technology in the United States, there is not an established documentation method for GOOSE-based schemes. Traditional hard-wired protection and control logic is typically documented on a control schematic. Engineers and technicians are familiar with these drawings. When these hardwired schemes are replaced with communications-aided schemes and relay logic, information is removed from the schematic diagrams, but the end-user still needs some form of detailed documentation of the scheme functionality. To address the need for documentation, the team implemented a tiered approach to the communications-aided scheme documentation including a functional specification, GOOSE mapping spreadsheet, and IED logic diagrams. A document flow diagram is shown in Figure 4. The objective of these documents was two-fold. The documents needed to aid the team in the implementation of the schemes, and the documents also needed to serve as an intuitive set of reference materials for the end-user. After completion of these documents and diagrams, the actual relay programming and GOOSE configuration were executed. The following sections describe the approach taken to each tier of the documentation.
I thought that goose messages are more spread in the United States and established documentation has been made already.
