Selection of Structural Members - Thump Rules
Good day all,
Please help me to sort out the issues listed below
Fabrication & Installation of Storage Shed:
I would like to understand how we would choose the structural members and their sizes if the requisition shows only the dimension of a shed. For example, requirement is to build a storage shed of length 6 meters, height 6 meters & width 6 meters. No member sizes are provided. What would you do if you have to choose the members and sizes for columns, base plates, rafter beams, ridge beams, purlins etc
Same situation I am facing for almost all type of structural steel jobs (like skids, handrails, platforms, stairs, ladders etc). I often do not receive much details. I am basically an estimation engineer and I do not get much time to perform load calculations to select the sections.
Please help me out.. I am facing serious issues due to wrong selection of sections.
Thanks in advance and your earliest responses will be highly appreciated!
RE: Selection of Structural Members - Thump Rules
Looks to me like you are being set up to fail.
Mike McCann, PE, SE (WA)
best regards
Klaus
Usually I am requested to provide budgetary quotes for steel works. I tried convincing the management several times by pointing out the missing details albeit I am forced to provide the quote in order to maintain the Client - Contractor relation ship. Mostly, Steel works in my projects carries little price implication nevertheless, I want it to be logical.
All I need is some thump rules using which I can do my estimate with max +/- 30% accuracy level in case of missing section details.
Or I will be so thankful if you can suggest any document or book where I can learn how to choose these sections and calculation of loads.
Hi Mr. Klaus,
I work in Qatar.
Thanks all for taking time to see my request.
Best Regards,
www.SlideRuleEra.net
www.VacuumTubeEra.net
Dik
