Starting Torqure et. al.
Hey Guys,
I typically answer Thermal Science questions on this forum, but now find myself being the one who needs to ask a question. It's in the physics/dynamics area, so I'm a little out of my area of expertise.
Here's the problem:
I have a paper roll 7 feet in diameter x 9 feet long weighing 5000 pounds. There is a metal shaft that extends through the center of the paper roll, extending 3 feet out on each end. This shaft allows the roll to rest on parallel pedastals.
During our process, the roll has to be rotated up to speed of 100 RPM from rest. This is done by hydraulically loading a 2 foot diameter rubber wheel against one of the shaft extensions. The wheel is driven directly by an electric motor, and as it turns, the friction between the wheel and the shaft causes the large paper roll to begin turning.
Now the questions:
1. How much starting torque is required to get the paper roll spinning and how do you work your way back to get the required motor torque needed to drive the rubber wheel?
2. How much hydraulic force is required to load the rubber wheel enough to ensure there is adequate friction between the rubber wheel and the metal shaft. I assume if this is too low, my wheel will just 'spin-out', right?
Thanks for any help you can offer.
Pharo of Thermo
Here's the problem:
Now the questions:
Pharo of Thermo
RE: Starting Torqure et. al.
A little 1 HP motor would do it if you have a while and the bearings are REAL good (low friction).
To find the torque at the motor, it will be proportionnal to the ratio of the diameters of paper's roll and motor whelle
Get the friction coefficient of the rubber and paper and by calculation you'll find back the pressure you need, considering the torque you need.
Note that pressure needed is independant of motor wheel diameter in theory but will vary slighty in practice.
The more you want to accelerate faster, the more pressure you need and a bigger motor you need.
Robin
Mech eng.
Canada
Following the early reply you need to calculate the "moment of inertia" of your paper roll and shaft first ie:-
moment of inertia for solid shaft (I) = m x d^2/(8)
where m = mass of shaft
d = dia of shaft
moment of inertia for hollow shaft (I) (paper roll)=
m1 x d1^2/(8) - m2 x d2^2/(8)
where m1 = mass of paper roll as though it was solid
m2 = mass of paper roll which would be the id of
the roll (in this case the id of the paper
roll would be the shaft)
next add these 2 results together and that will be the
total moment of inertia for your system.
to find the torque required to bring your system upto
speed use the following formula
T = I x ((w2 - w1)/t)
where T = torque req to bring roll & shaft upto speed
w2,w1 = final and intial angular velocity of
shaft and paper roll
t = time that you want the system upto speed
(you can choose any value and work the torque
out from the above formula)
I = the total moment of inertia
once you have the torque you can calculate the the
tangential force on the shaft which needs to be exerted by
the tyre.
I am not sure how you calculate pressure in the tyre although rolling friction as stated earlier will come into it.The complication here for myself is that the tyre will deform to some degree and I am not sure what area the pressure will be working over. The only two suggestions for this problem are 1/ use trial and error and pressurise the
tyre to various pressures and try it
out.
2/ perhaps somebody in the automotive
line could help out with the last
part.
Hope this is of some help
Following the previous reply, the friction force is, in theory, indepentent of the surface area. It is F=uN where the force you can apply tangetial to the roll (F) is dependant to the normal force (N) and a friction coefficient.
This force F os the furce you'll use to calculate torque required at roll and torque required at motor b multiplying by the radius of the roll.
I do not see any coefficient of friction for paper to rubber but wood on metal is around 0.25. I say around because they can vary with many factor and can doulbe in no time. Furthermore, the theory says that the phenomenom is independant of the surface of contact but the surface has some effect.
Robin
Whilst I see formula regarding friction in the same light as you have shown above which is dry friction, I would point out that the friction force is actually "almost" independant of "apparant area of contact" but the friction force which is determined by the true area of contact, is proportional to the load applied.
Further it is interesting to note that if you reduce the pressure in your car tyres you will get additional grip on the road surface.
regards desertfox
Pharo of Thermo
Can you please attach a sketch of rubber wheel coupled to the motor.As usual,it is easy to calculate external inertia and therby we can calculate motor Power.Do you use inverter drive for this particular motor.If so you can set the accelaration time for this system and you can arrive at the motor Power.If Inverter drive is not there, you may have to assume accelaration time of a normal squirrel cage induction motor as 2-3 sec and calculate the power by using inertia formula.
Let J0 is the sum of inertia reflected at motor shaft
Then Accelaration torque= J0 x 2 pi N/60 t
Where pi= 3.14
N= Rated speed
t= Accelaration Time
You can normally overload the motor by 6 to 7 times for 2- 3 secs. Check whether you get the torque within this limit
Once you perform this calculation , I can help you out to find the pressure required at the wheel.Its better to divide your problem into 2 halves
1> without rubber wheel estimate motor power by using inertia formula
2>Introduce rubber wheel and re iterarte the motor power. I need your schematic sketch to do that
You can contact me at sudev.krishnanair@bwir.com
Good luck
Bye
Sudev Nair
