Spray Paint Cans
Spray Paint Cans
As I get older, I find I have less tolerance for cans of spray paint that don't. I have always religiously followed the instructions to shake the can for at least a minute after you hear the ball start to rattle and then invert the can to spray out the pick up tube when you are finished painting. I also used to clean out the nozzles with fine wire. I used to soak the nozzles in a jar of lacquer thinner. I used to stick the nozzles on a can of brake cleaner to blow them out. These days there are more nozzle sizes/configurations on the paint cans and cleaner cans that this method is no longer practical. One method I have found that works is to shoot the offending can with a .22. Then they spray real nice.
RE: Spray Paint Cans
Keith Cress
B.E.
You are judged not by what you know, but by what you can do.
https://www.ebay.com/sch/items/?_nkw=spray+can+noz...
perhaps the designer will soon make non-replaceable nozzles.
all the more reason for destructive entertainment.
Doing that, the experience has been very rare to have a can fail to spray... Very simple solution to prevent ,
Keith Cress
I've found that I can use my compressor to re-pressurize cans sometimes, as well as blowing the nozzles clean.
And sometimes it doesn't work- lots of times the smartest thing is to toss it and use a new one...
Jay Maechtlen
http://www.laserpubs.com/techcomm
