Drucker stability
Drucker stability
i want calibrate a hyperelastic rubber in abaqus, i have experimental data and i want use Mooney rivlin and Yeoh.
But, also, i want check Drucker Stability?
can i do it?????
is there a internal tool in abaqus or i must create a subroutine, and in this case how?
thanks a lot
can i do it?????
thanks a lot
RE: Drucker stability
Also, there is a calibration utility built in in Abaqus/CAE. I recommend looking in to the documentation for more.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
How can i do it with isigth?
For convex curve you intend in material calibration with the use of test data?
tanks a lot
Assuming you are familiar with nonlinear continuum mechanics, then you could plot the strain energy potential against Green-Lagrange strains (E_ij) for the strain ranges of interest.
All of this said, you do NOT have to do it. Abaqus does it for you. Check the documentation.
