Doble F6150. ProTest.
Hello!
I need help using the Doble F6150. I'm using the ProTest program. Q: Is it possible to edit test plans in a text editor? I have a large group of test plans, which should differ in several parameters. I would like to be able to quickly edit them in one window of the text editor.
I tried to open the protest.db file in a text editor, but it does not contain information about test plans.
RE: Doble F6150. ProTest.
There are several worksheets - one is global and that is where the settings can be imported to. Each macro also has a worksheet. I dont think you can import from that level. If you have not upgraded from ProTest to protection suite, you should consider as I believe ProTest will no longer be supported. Protection Suite has a conversion utility to take care of ProTest macros.
I do not see this function to import in my ProTest.
